Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 Questions View all
Turns off with popping sound when moving the 3D depth slider
Hey! I replaced the charge port on a 3DS today and now when I turn it on and move the 3D depth slider up a little there is a popping sound and it shuts off. Could this be something to do with one of the flexes inside? I checked them all and they seem ok with no damage. Has anyone seen this problem before?
Score 1
Add a comment
Chosen Solution
I managed to solve this issue a while ago by replacing the speaker flex cable that runs through the hinge on the device. It becomes damaged very easily from opening and closing the lid.
Add a comment
The 3ds depth potentiometer is connected to the speaker flex ribbon connector which connects here http://www.consolezombie.com/Images/3DS/...
the replacement is very difficult. the speaker flex is like 3 dollars but you have to solder your own speakers. if that one flex is broken i bet the other might give out.
my suggestion reseat the ribbon connector for the speaker wire. And if that works then dont close your 3ds anymore.
dont even go into the top lcd parts unless you watched several videos and already purchased replacement parts and have fixed phones before. the cables have to be wound up to fit throught the hinge part difficult and the other hinge has a lock part.
ps careful when lift in sd card port u dont want to life the metal underneathe it. you dont need to do that. but if you do i suggest putting the screws back under the sd card slot to hold the metal part down while you lift off the sd card from the adhesive. only need to do this first time
Add a comment
I have not had this problem but have you had my problem check out mine. I suggest going to the store and asking them to look at it. if that doesn't help return it and get a new one. that's all Ive got but i hope it helps.
Score -1
Add a comment
Add your answer
craigad24 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 5
All Time: 297
