How can I stop my Xbox from overheating?
My Xbox has the 2 red rings of death and overheats within 5 minutes of being turned on. I have tried placing fans around it to keep it cool but nothing seems to be working.
Stormy Waters, You most likely have issues with your GPU processor. It is a flip chip design and the issue could be the solder bumps between the IC and the substrate. You could try the RROD fix kit from ifixit. The kit is strictly providing additional pressure on the GPU/CPU to try to close cracks in the solder joints ( as well as reconnecting the bumbs, long story). . Combining this with a reflow with a heat gun may just complete a good repair. Check on here step 49 will explain it. Check on here for the reflow guide. Also "remember that all that this kit is trying to accomplish, is to close cracked solder joints. Most of the time the extra few pounds of torque provided by the kit, will close those cracked joints. It is not a permanent fix, nor is it a sure thing either. It all depends on the individual logic board and the damage to the solder joints as well as the chip itself I strongly suggest a reflow with this kit. The chances to be successful is greater with a combination of RROD kit and a reflow. Of course, a permanent fix would be a total reball. for a reball to be done, you will need the stencil, a rework machine as well as the proper reball temperature template, and a new processor. If you do not have those tools, you can not do a reball.
Guide
Difficulty:
Difficult
45 minutes - 1 hour
Guide
Difficulty:
Difficult
1 - 3 hours
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 73
