The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
My power button has some problems.
Hello. My Samsung Galaxy S3's power button doesn't work properly. If I push once to button, it senses like I'm holding and restarting itself many times consecutively. Because of this problem, I decided to repair the button and started to search. I'd be very happy if someone describe how to repair the button.
Thank you.
Score 1
Add a comment
1 Answer
Chosen Solution
Hi,
the power button of the S3 is soldered to the logic board. It's not so easy to replace it, without killing the solder pads on the logic board, if you are not good in soldering.
Score 1
1 Comment:
I guess I should understand that this is not an amateur task. Thank you for the explanation :)
by
Add a comment
Add your answer
Ahmet will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 275
