Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Question Closed
RAM supported by a MacBook Pro 13in mid 2010?
I have already installed 8gb and am wondering if it's possible to upgrade to 16gb. Some forums says the maximum a Macbook Pro Mid 2010 supports is 8gb while other says it's 16gb.
Could someone clarify please? My model is Macbook Pro Mid 2010 13in.
Add a comment
1 Answer
Chosen Solution
Yes! It can be confusing!
First here is my goto source: EveryMac.Com - MacBook Pro 13" 2.4 GHz Core 2 Duo (Mid-2010)
I can tell you with the latest firmware update: About EFI and SMC firmware updates for Intel-based Mac computers or newer as some OS updates update the firmware. Get the correct memory modules (1066 MHz PC3-8500 DDR3 SDRAM) 16 GB of RAM. Make sure you have a matched pair and get them from a good source.
Lastly, you'll need to be running Mavericks or newer OS-X
Score 2
3 Comments:
Thank you mate! That's really helpful. I think I've found the model you mentioned on your comment. Is this the right one?
http://www.amazon.co.uk/computers/dp/B00...
by
The specs are correct. Sadly, I don't know this company (there are quite a lot of resellers out there!) Thats not to say the modules won't work. Just make sure you can return them if they have a problem.
by
Thank you, Dan! Will give a try on that model, let's see what happens. I believe they do accept returns in case something goes wrong.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 127
