Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Touchscreen not responding, even after LCD/Touch replacement OEM
So i have encountered some issues with iPhone 6 and iPhone 6 Plus.
The touchscreen will freeze and to me make it work again i need to restart the phone, i thought the issue will get fixed replacing the LCD/Touchscreen assembly. But it persists. The chasis was a little bent and also thought this is causing this issue, but even after straighten the issue persists.
What i have done and haven't fixed my issue:
  1. Replacing the LCD/Touchscreen assembly (aftermarket)
  2. Swapping the LCD/Touchscreen assembly from a functioning iPhone 6 to this one
  3. Straighten the chasis
  4. Have the inner chasis covered with thermal tape
  5. Restoring the the iOS
Does anyone have encountered this issue? And knows how to fix it?
Thanks!
Score 1
Add a comment
I have the same problem: Touchscreen not working - even after screen replacement
Might be something called "touch disease": Touchscreen Periodically Not Working
Add a comment
Common issue. It's Meson IC, you need to reballing.
This rework requires high skills and professional equipment.
Add a comment
Add your answer
Robert G will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 160
