Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Question Closed
for F9800, Is it 2A 32V 0402 or 3A 32V 0603?
Which is the correct component for F9800 fuse in... ( details are below )
Apple Logic Board: 661-5203
Device: MacBook Pro 17" Unibody Mid 2009
Model: A1297, 820-2610
Serial Number: W******V8YA
Is it "2Amp 32V SMD 0402 Package" or
the "3Amp 32V SMD 0603 Package" ?
because these pages got me little confused with F9800 & F9700 on the logic board.
Change F9800 fuse 820-2915-B
Location of backlight fuse on Logic Borard?
but by the fuse dimensions, 3Amp 32V SMD 0603 package determined as the correct fuse...
Just want to double check !
Thank you so much for the support !
1 Comment
Kenneth, "because these pages got me little confused with F9800 & F9700 on the logic board." its because you are looking at different boards and different models :-)
by
Add a comment
1 Answer
Most Helpful Answer
Kenneth, here is the location of the fuse. It is a 3Amp 32V in a 603 package. Please remember that this is only to identify the fuse. If the fuse is blown, you will definitely have to check on the reasons why it blew. It's a pretty big fuse and it takes quite a bit to blow it. So check your LCD connector and other components for a short circuit.
Score 1
1 Comment:
Thank you so much for the clear and lucid explanation !!!
This backlight of the LCD monitor has been on and off for last 2 month.
so, I was using my MBP with an external monitor, but in some cases... it becomes a primary monitor...
however... eventually last week, backlight went out!
so, for me... it is an abstruse to conjecture that which component caused the short circuit.
reluctantly, at this point... I would like to put one more chance to my MBP.
Thank you once again for your time and support !
Have a happy wonderful day~~~*
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,025
