Model A1418 / Mid 2014 / 1.4, 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
50 Questions View all
Question Closed
Can I add Samsung 850 EVO 500 GB M.2 3.5-Inch SSD?
Hello,
I am using iMac 21.5" core i5 2.7 late 2013.
The question is: I want to add new PCIe SSD drive to make the fusion drive. Can I do that with Samsung 850 EVO 500 GB M.2 3.5-Inch SSD or any recommendation?
http://www.amazon.com/Samsung-2-5-Inch-I...
And: Samsung SM951 512GB AHCI MZHPV512HDGL-00000 M.2 80mm PCIe 3.0 x4 SSD - OEM is compatible with my iMac?
And one more questions: I want to replace my current RAM with Kingston HyperX Impact Black 16GB Kit (2x8GB) 1600MHz DDR3L CL9 SODIMM 1.35V Laptop Memory (HX316LS9IBK2/16). Is it compatible and work properly?
http://www.amazon.com/Kingston-HyperX-16....
http://www.hyperxgaming.com/us/memory/im...
Impact SODIMM - 16GB Kit*(2x8GB) - DDR3L 1600MHz CL9 SODIMM
Part Number: HX316LS9IBK2/16
Specs: DDR3L , 1600MHz , CL9 , 1.35V , Unbuffered ,Spec Sheet PDF
Timings: 1600MHz, 9-9-9, 1.35V/1.5V; 1333MHz, 8-8-8, 1.35V/1.5V; 1066MHz, 6-6-6, 1.35V/1.5V
Thanks
Add a comment
1 Answer
Chosen Solution
First you should review this IFIXIT guide: iMac Intel 21.5" EMC 2805 SSD Replacement. As you can see you need to take the logic board fully out to gain access the blade SSD socket. This is a very big job! I also must warn you taking the display off requires the proper tools and care as you can easily damage the display just in the process of taking it off. Note the 23 steps needed to just take the display off!
Now the nitty gritty here:
Please review the custom Apple SSD made by SanDisk: SanDisk SSD now compare it to the Samsung M.2 SSD: Samsung 850 EVO SSD. As you can see the connections are very different. These drives are not compatible. You need to use the custom Apple blade SSD and you need to use the correct unit for your system.
As to the memory review this image: Logic board. Just to the left orange marked screws is 4 chips (8 GB 1600 MHz LPDDR3 SDRAM) as you can see these are soldered to the logic board and are not replaceable.
So the bottom line here is this system is not really upgradable! I would recommend you look at getting another system that meets your needs as is, or get a system that is upgradable. If you can swing it I would go with a Mac Pro or if you want a lower cost solution get an older 21.5" system (pre thin series).
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 680
