Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
1233 Questions View all
Question Closed
Worth trying to fix?
Trying to determine if it is going to be worth trying to fix my 5c myself or not.
Several things happened and now all my phone does is make a pong noise when it's plugged in. I got this point after the battery started over heating after being on for certain amounts of time, then after a while the LCD would fade and get vertical lines down the screen while fading out entirely. The final thing is that I accidentally dropped it, and now it doesn't turn on at all and just makes the noise described above when plugged in.
I'm thinking if I replace the LCD and battery I will be okay, but I don't want to invest if its not going to work. Please help! TIA
Add a comment
1 Answer
Chosen Solution
MetalMomma. from what you describe that should be the way to process. The pong noise is most likely caused by the LCD not responding to the iPhone's self test. If it is " going to be worth" to be repaired is always a crap shoot and will depend on how much you are willing to spend etc. I'd do it...
Score 1
2 Comments:
Thanks! I think I'm going to do it.
by
That's the spirit!!!!
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 128
