Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Question Closed
Home button stopped working after repair, but Touch ID is fine?
After a screen repair, the home button stopped working after a couple days, while the Touch ID continued and continues to work.
I ordered two official Mac metal back shields with home button flex ribbons. I put a new one in and made sure the home button flex cable was seated properly to the home button flex ribbon multiple times, as well as the flex ribbon to the corresponding connector on the logic board. No luck.
After this I connected the remaining new back shield while the other one was on, while the phone was still apart and it seemed to work fine. So, i put that one on, and it didn't work. Again I made sure everything was seated properly.
Does anyone know what problem I have, as well as a solution?
I would greatly appreciate it.
My next (and current) step is to buy a new home button flex cable and replace that, to see if that solves the problem.
2 Comments
God this is weird. I'm wondering if something is shorting out the cable, when you put the assembly together?
by
I thought this as well, but wasn't able to find anything.
by
Add a comment
Most Helpful Answer
I would be careful about replacing the home button flex as you will run into "error 53" if you try and update your phone in the future. Have a look at the connector on home button flex and see if it looks damaged.
Score 1
1 Comment:
Thanks for the reply, but the connector looks fine. I'm going to try a new home button next. Will respond with update.
by
Add a comment
you will lose touch ID by replacing the home button
1 Comment:
I'm well aware of this. It's only a test to see where the problem lies.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 8
All Time: 122
