Repair guides and support for phones manufactured by BLU Products. BLU stands for 'Bold Like Us.'
1766 Questions View all
Question Closed
Picture recovery after falling in pool
BLU pure life
I had a BLU pure life phone, it fell in a pool and now it will not turn on. I was wondering is there any way to recover the pictures that were in the phone?? Maybe there is something I can do to at least save my pictures.
Add a comment
1 Answer
Most Helpful Answer
Lina Guarnizo , first off skip any rice. It is absolutely useless. It will not help you fix your phone. All it does it provides a false sense of security. It will not clean your phone, it will not prevent corrosion.
Second, stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. You cannot get your pictures back from your phone if it does not start. There is no software that will allow you to do that. You will have to try to recover your phone at least long enough to connect with your computer.
The very first step I would take is to disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Use a soft brush and clean it very, very thouroughly with sterile water. Remove all the EMI shields. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. If you can, get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. Keep in mind that water damage is the hardest to troubleshoot and to repair.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 47
