Startup loop won't stop
At first... It was shut down and restart when it connected to internet, and afterwards it gone in a startup loop to the logo and shutdown again.
I cannot stop it or complete start my tab.
Try a hard reset. Here's a video on how to do it: https://www.youtube.com/watch?v=L2nFwCzf...
i've tierd this and it faild "wipe data faild" error : connot get phone encrypt state"
i also tierd flash officail stock room but i couldn"t cuz it keep restarting (usb disconnect over and over) than tried to use adb to flash it but the "usb dubbing " wasn't actived
and no matter i try to installe rom (zip file) or any other package using recovery mode i get this" installation aborted"
If you encounter the mount /data error or error mounting data message in the recovery mode of your MTK Android (e.g Tecno, Gionee, Infinix, Opsson, Innjoo etc) phone then your /data or /SD card partitions might be corrupted. To fix this, try the methods below:
Format SD card (If there's a slot for it)
* Remove the SD card
* Format the memory card on a PC (FAT32)
* Slot the SD card back in and boot the phone normally
* Switch off then boot into recovery mode
* Re-try the operation
Wipe data & eMMC
* Boot into recovery mode (volume up + power) and select Wipe data / factory reset
* If the above fails, boot into Chinese factory mode (Volume down + power) and select the option with eMMC in its name
* Reboot the phone
thank you the quick answer but ....
there r no sd card on the phone just the internal storage 16GB i guess
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 22
All Time: 6,966
2 Comments
i have your problem in my tablet can i ask you how you fix it pleas
by sweetmimi1984
I have the same problem in my device. so far I can not solve this problem. if your problem was solved, please help me? thanks in advance.
by ayman massoud
