Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1526 Questions View all
Touch screen unresponsive when touched but 100% visible
I replaced the screen on my gold 6 plus, I decided to put a black screen on Iit and everything went well until I turned the phone on and the screen was unresponsive to touch. Before complete installation I did test the screen and it worked . The screen has light lines running down the screen please help
2 Comments
Does the home button work?
by
I didn't attach the home button backing plate yet because I have a stripped screw and ordered a new plate, but the touch id was still funtioning
by
Add a comment
Chosen Solution
I would take the phone apart again and get it to were it worked before then re assemble slowly and with care checking when possible if it works to know when things go wrong.
Score 1
Add a comment
Most Helpful Answer
Sounds like the digitizer flex cable or socket on the board may be damaged. I would inspect those areas under a microscope.
Score 1
2 Comments:
Could also be a short , did you put all the insulating tape back on?
by
When I extend the flex cable while it's plugged in the screen becomes clearer, but still lines going through
by
Add a comment
Your digitizer flex isnt properly plugged in most likely.
1 Comment:
by
Add a comment
Touch input all jacked up after multiple screen replacement attempts
^Try this.
Add a comment
Add your answer
Josh B will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 338
