Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
2nd Replacement LCD not working.
I have just attached
Got the 2nd LCD home last night and replace the previous LCD. When I turned it on, it showed the battery was depleted for 1 second and then went dark. I connected it to the Mac but, while it vibrated, nothing displayed. I reset connector #1, 2 and 3 (which I think doesn't go in far enough for me). Nothing. Zip Nada.
This last display at least showed the depleted battery icon for a second. The previous one never showed any life. I know the iPhone is alive: it vibrates when connecting and it appears in iTunes. I reseated all connectors 3 times. And still nothing.
Any suggestions?
Thanks,
Allex
Score -1
Add a comment
1 Answer
Chosen Solution
take a look at the dock/connector 4, it may be not lodged properly. i take it that if you are replacing the lcd you have dropped it? if it has been dropped at the bottom sometimes the dock is damaged and therefore there is no way of power getting to phone/battery and itunes can't recognise phone. it may be that the battery has now run out of life because it can't charge via dock-hence your short screen life, which now shows nothing. clean dock port with isopropyl alcohol, look for dust/dirt in bay. check ribbon 4 is connected properly. the other problem may be that battery connection is dislodged....check under the "don't remove" sticker. maybe the prongs that make connection with battery have been damaged. if so you can try to gently pry them up. dock connectors are fairly cheap to buy.
Add a comment
Add your answer
allexv will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,377
