Repair guides and support for your Samsung TV.
thin black lines on the screen started with one now four
thin black lines appearing on the screen of my 50" Samsung television...color is great but these keep appearing one by one on the top portion of the screen. Is there a fix for this.
Score 4
3 Comments
What kind of TV? LCD? Plasma? DLP? Projection? Do you have a model number?
by
my t. v. is a 26 in. hd mintek flatscreen combo with a dvd player
by
Kind of funny everyone has the same brand and the same problem.
by
Add a comment
Chosen Solution
If this is an LCD screen look closely at the screen and see if you can see where it actually starts if you can find it take a pencil with an eraser on the end and place the eraser on the spot were it starts and apply a small amount of pressure a little at a time and release . Do this a few times or until the line goes away. Lines can be made by dead pixels. A small amount of pressure on the LCD can fix this, be careful not to use anything sharp. This does not work with plasma or LED screens . Hope this helps
Score 15
20 Comments:
I don't believe it. IT WORKED!!!!!! Thank you , thank you, thank you!
by
This worked for me too:) WOW!!
by
It worked for me thank you very much Russ in Colorado
by
Worked for me too! Holy crap! Glad I didn’t try to figure out a fix on my own before finding this!
by
Holy crap!!! This actually worked. Thanks
by
Show 15 more comments
Add a comment
If the lines are appearing and disappearing then it is not dead pixels you are dealing with but it could still be related to pressure.
If you are careful you can troubleshoot the problem yourself. You will have to work with the back panel removed leaving boards exposed that contain very high voltages.
With the back panel removed at the top of the casing you will see a long circuit board (Usually about the length of the screen) There will be a number of ribbon cables plugged into it, coming from the front of the casing, the cables power different sections of your LCD screen.
Now with the TV propped up power it on and play something as you normally would, find the ribbon cable at the top that is closest to the lines on the screen, carefully you should be able to move the cable a little, see if the screen corrects itself.
If so, plug the TV out and press the power button a couple of times to discharge any remaining power.
Now lift the tab for the cable you identified and push it in fully and clip the tab back down on it, turn on the TV and see how the picture looks, if it is good then close the machine back up and enjoy some TV.
Score 2
Add a comment
If the TV is hanging on a wall-mount then that could be what is causing it. The pressure on the back of the TV tends to bend the LCD display so that these lines appear. Not a fix... Just saying. This especially happens with cheaper TVs
1 Comment:
What if i have a led samsung 47 inch but theres thin and thick black line on the screed how do i make them go away its a model nyo2
by
Add a comment
Sony XE8577 55”
I have these darker line areas at top of screen to 10cm down/ 15cm wide. Sony services says that it´s not anything problem at my tv and they don´t want to repair it(under year old), but if I want to deliver at my own cost to repair it´s okay :) So be careful if you consider to buy a Sony. Funny from Sony I say.
1 Comment:
Sony is not the same company it used to be back in the day. Their products are not as reliable as before, many of which are not even their own anymore, but simply other manufacturers' rebranded hardware. I have discovered that the internals of many Sony products these days are actually made by LG. Personally, if I wanted LG hardware, I would expect to pay LG prices for it, not the SONY premium.
At one point before the turn of the century, there was not a single electronic device in my home which did not bear a SONY brand logo because I only wanted to buy things once. They apparently started to cheap out on the manufacturing quality control around the late 90's. The last Sony product I purchased was a VAIO desktop in 2000 which lasted far longer than it ought to have at 12 years of use before retiring, but the TV I bought in 97 died by 2002. The monitor I bought to go with the VAIO was a Samsung with a better picture and a lower price than the SONY counterpart, and it still works today.
by
Add a comment
Add your answer
Penny will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 72
All Time: 302,207
