Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Questions View all
lightning cord broke off while removing it from iPad , jamming port
Half of the metal charger broke off, leaving other half stuck inside my iPad mini.
How can I fix this?
3 Comments
I've tried EVERYTHING, and cannot get that little tiny bit of the charger out of the port slot. I've tried using the tiniest tweezers and nothing works, it won't budge. The Ipad mini is my daughter's and the reason it happened was because she would just yank the cord out instead of being more careful and unplugging it from the source. I went to the Apple store and they said that it would cost at least $300 to fix it! If you google about this you will find its happened to hundreds of other people too, but nobody seems to have the solution that works for us.
by
Taking a closer look at a Lightning cable and dock, the cable snaps in on both sides. Its going to take some work to get it out. If you can't get a set a tweezers in there, it might be time to take it to a shop. A dock replacement is pretty straight forward on those. I would not do superglue as the dock is plastic the the connector is metal, so the glue will bond with the dock way before and way strong than the connector.
by
I always think that if Steve Jobs were still alive he would never have changed the connector cord to begin with. The lightning cord is cheap, flimsy, it frays easily and should've been made stronger.
by
Add a comment
Most Helpful Answer
Can you fit a set of tweezers in there?
I've honestly never had this. I am tempted to break a lightning cable off inside one just to find out how to fix it.
Score 1
1 Comment:
see my comment below!
by
Add a comment
Like a broken-off headphone plug, some people have had luck using superglue on the remainder of the plug and using it to pull the broken-off tip out of the lightning socket.
Here's an example from YouTube.
This is inherently risky, so be careful!
Score 1
4 Comments:
I tried that and it did not work. Honestly, After trying it I don't know how it could've worked for the people who suggested it, either!
by
Yes it is very tough. The other thing to try would be a pair of 'needle point' tweezers,. The port has a little more width than the plug...and fixit does stock these.
by
Trying the glue method not only didn't work - it completely ruined my chances of getting the metal piece out of the slot at all! To those reading this -- don't even try it!
by
I’ve managed with the glue method...once. It’s hard, and likely won’t work. You are much more likely to succeed with long needle point tweezers, grasping by the narrow sides where there is a little room, NOT on the obvious wide/flat sides as there is no clearance there.
by
Add a comment
so i was takin the charger of my phone and it just broke
Score 1
Add a comment
fishing hook works well
Score 1
Add a comment
get something tiny and add glue to it and then put in the pes that is stuck and then let it driy and last you pull it out.
Add a comment
I got the whole metal piece stuck in the phone. I got mine out with some small toe nail clippers from the dollar tree.
Add a comment
Add your answer
nkelley will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 10
All Time: 7,575
