Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
microfone and hear after changing vibrate/ring switch button
Hello,
i bought from you and followed your guide for changing the vibrate/ring switch button .
My iphone is working but i have a problem: can't hear on calls and can not be heard.
i think it has to do with button with number one on your guide (one of the first screenshots).
But i am not having it easy to connect that button.
(butto 3 shows up in step 6 on changing ring/vibration button guide)
Have you got any suggestion?
Tks,
Luis
Score -1
Add a comment
1 Answer
Chosen Solution
since you have 2 mainly unrelated problems - i think you didn't connect the ribbons 3 (earpiece) and ribbon 4 (microphone) correctly.
so the only way to find out is to disassemble it again and check those connections - they can sometimes be very tricky - but if you are careful - you can make it (and don't try to break it)
good luck
5 Comments:
tks for your help.
i have checked and microfone is working correctly, now that i have corrected a connection. but i still can't listen to anyone in normal mode (in external mode i can listen ..)
which should be problem?
tks again
by
does the phone "switch" when you cover up the proximity sensor during a call?
by
nopes. it stays with the screen on.... do you know what is the cable to see if has any problem? tks
by
this should be a problem with cable #3!
by
that is what i think, but i am not being capable to insert it all the way... lol
i'll try again later.
tks for your help
by
Add a comment
Add your answer
luisneta will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,161
