The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 Questions View all
ipad air LCD not turning on after digitizer replacement
hello , i got the same problem with my i pad air 5 where screen stays black after digitizer replacement. funny thing my battery was disconnected during replacement. any ideas?
i tried reseating clips, home button and off button hard reset old digitizer also not working.
I pad is detected by iTunes and when i connected the charger the charging sound keeps beeping continuously. please advise
Update (09/15/2015)
I think I found the problem. does any one know what this part is called and how to go about it. my soldering skills are rubbish. is it a fuse of some kind. how could this have happened if I was wearing static band and battery was disconnected.
Score 1
Add a comment
1 Answer
The backlight filter is possibly blown. I have run into on either a mini or an ipad air, I don't remember which, a situation where I thought I had killed the backlight filter but it tested good so I put a different lcd on it and it worked. After that, I put the original lcd back and it worked fine. I never did figure out what was screwed up but it may be worth giving a try.
Gotta try the easy fixes before chasing after the board work so try a different lcd first. Maybe even disconnect the battery and let it sit for 30 minutes or so disconnected and come back to it. They're finicky.
Add a comment
Add your answer
frankmasiko will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 606
