The Huawei H881C, also known as the Huawei Ascend Plus, or Ace is an entry level prepaid smart phone from the carrier Straight Talk, a subsidiary of Tracfone.
22 Questions View all
Question Closed
Phone will not charge, tried everything
Noticed it wouldn't charge with my wall adaptor so I figured the cable or charger and given out. Plugged it into the one in my car annnnd nothing. Got home and decided to try the car chargers cord with my laptop and it charged for a few seconds then quit. It would cycle between charging and not charging and has finally stopped even doing that
Add a comment
1 Answer
Most Helpful Answer
Zach Brennan, start off with a new battery. It will not charge if you have a bad battery. Once you replace it and you use a proper cable and charger, reevaluate. Should it still not charge, you will have to take a closer look at the components on your board. It is possible that your PMIC has failed.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 71
