Budget monochrome laser printer, released in 1996.
2 Questions View all
Question Closed
Why is my HP Laser Jet 4+ crinkling up paper and jamming
My Laser Jet 4+ is crinkling up paper and jamming. It has never done this before. I am using only 20lb paper. It has been so reliable, I am wondering if there is something that needs to be adjusted.
Add a comment
Most Helpful Answer
Check the paper path to see if there is some paper or other object jammed in there. In addition, the rubber rollers that push the paper along do eventually shrink slightly and harden. A kit to replace them is typically about $20.
Score 1
Add a comment
do what Dak said. I had the exact problem and it seemed to be clear of any objects. I took it apart from the back and a few small parts from around my shop fell out of it. I thought i had to buy a new one and it started working perfectly. Be sure to pull the back off though and not just check the input where the paper goes.
Score 1
Add a comment
Usually when an accordian jam occurs in this type of printer, it happens in the exit / fuser area. Replacing the exit delivery rollers RF5-1076 and 1077 that are located in the back of printer will fix this accordian jam issue, otherwise its the fuser assembly.
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 332
