Why is the screen loose
in the middle where my front camera is. it Is loose and I am always having to push it down as it loose what can I do ???
also everytime I push down on it, it makes a clicking noise ?
In the area you describe, there is a metal cup which *should* be stuck to the underside of the glass screen - this helps to keep it intact with the frame of the body of your ipod.
The only other thing holding on your ipod screen, all the way around is glue.
Id be surprised if this has happened to an ipod that had never previously been opened - quite likely on one that has though.
If the rest of it is fine, personally I would put a small dab of super glue literally just under the glass - HOWEVER - BE VERY CAREFUL!!!
IF you do decide to do this, know that the cables for the digitiser and LCD are right there in this area. If you get it wrong, and the glue touches these cables, its likely to ruin your entire screen. If you go with a very small amount, and keep it to just the very edge you will be fine. I have done it many times, and will continue to in the future - just proceed with caution is all.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 123
