Repair information for vehicles (other than cars and trucks) that get you from one place to another.
2179 Questions View all
2 wheel electric segway: Light not red when charging for 1st time
Went to charge it for 1st time, light wont turn red.
So I bought a two wheel segway and after a great deal of time, it finally arrived. My friend and I rode it all day yesterday and had loads of fun. Naturally the segway light blinked red, meaning it was time to charge it. I pulled out the new charger (MODEL: Hk-42-2000 INPUT: 100-240VAC, 50/60Hz, OUTPUT:.42V) and the light stayed green. According to the the instructions, the light is suppose to turn red when charging and turn green when fully charged 2-3 hours later. So I tried many different outlets and tried switching the plug in pieces different ways and still had no luck. I left it plugged plugged in for an hour just in case, and the segway said it was dead. Lastly another thing to mention is when I unplug the outlet, the box turns red for 10-15 seconds. What should I do, any help well be greatfully appreciated!!
Score 22
19 Comments
I bought a hover board , I charged it and the charger turned green meaning ( full charged ) but when I go on it the light turns green / red . Can anybody help? * I don't know what's wrong with it any help can help * thank you .
by
My hover borad fully died what do I do (can't turn on) and when i plug the charger in the light is not green anymore there's no Colour that comes up once I plug it in but when I un plug it the green comes on (the brick)
by
I bought a Hoverboard 4 weeks ago and 4 days ago when I charged it for 2-3 hours it wouldn't charge the charger stays green when trying to charge Hoverboard and after leaving it for 4 hours it still wouldn't charge when I turn it on the light beeps red !! What should I do please I need help I'm obsessed with this electronic please if I could get directions I would appreciate it
by
My charger will stay red for about 5min, then it will turn green, but it will stay red on the hover board and blink. Any solutions?
by
U have to charge your hoverboard for 1 hour.
by
Show 14 more comments
Add a comment
Chosen Solution
I am having the same issue with mine. My son and I tried it out for maybe a total of 2 hours ride time off and on before the battery light on top that was green started blinking red and beeping at him. Our charger stayed green when we plugged it in. I left it charging for 1 hour ... checked it -- it was flashing green (meaning at 50% according to the manual) Left it charging for another hour (states 2-3 hours - assuming 3 hours max!!) still blinking green. At hour 3 (my last attempt) the battery light on the swagway was solid green so we were excited!!! Got on it and it quickly turned to red blinking then beeping at us again :( So sad about it and frustrating!! What happened to yours??? It's not a calibration thing is it?! Because I think that is the solid circle light when it blinks red.
Score 6
5 Comments:
Use a phillips screwdriver and open it up on the charger male side. Check to make sure the charger wire is tightly fitting. When I opened my sons, the wire wasn't connected at all. Plugged it in and no problems since.
by
The light on my charger stayed green when trying to charge and it seemed like I had to push hard on the end of the charger to get it to connect to the hover board. I took it apart and there wasn't any loose wires. After I looked at the end of the charger and saw the groove, I found where groove lined up with the hover board connection. On the hover board connection where the charger goes, there is a small notch that sticks out be sure the groove on the charger lines up with that. Mine went on easy and charged perfectly.
by
We also had trouble charging my sons for the first time after using it. I read many comments on this website and found that you can actually put the charger into the Hoverboard wrongly and therefore the charging light stays green. I unplugged everything and then found out that there is a groove in the board charging dock and charger connecter that have to be lined up. You then plug the charger into the socket and not before?? Hey presto the red light came on and it charged.
Hope this helps
by
Thank you just found the little groove segboard charging atlast
by
When I go to plug mine in my ninebot mini pro beeps once the red light on the charger comes on for a second or two and turns green. No indications of it charging. What could be the issue? Is their anyway to fix it?
by
Add a comment
Well same thing happened to I think that the problem is that inside the Segway the charger hole inside it there's a cord and that might be loose or u might just need a new charger
Score 4
3 Comments:
Hi I need advice please ..my sons segway is completely dead ...when I try to charge it the battery is on green constantly but the battery is flashing red on the segway and there's nothing at all ...please help thank you
by
Believe it or not I've just had the same problem on my Grandsons Segway! stripped it down and found the on switch was faulty bought new one from amazon (less than a tenner) delivery tomorrow -- might be worth a try - just remove the cover on the charger(non-battery) side and check the wires which go to the on button , remove it from the pcb board and put a small screwdriver across the terminals . This acts the same as pushing the button on. - if it turns the board on -happy days - got to be worth a try
by
So just received the new on button and fitted - working perfectly. Looks like the button might have been affected by the elements- my grandson said he went through a puddle - I bet he did! anyway its fixed it.
by
Add a comment
On the charger is a transformer and bridge, I don't know about Segway products but you probably blew a diode. There could be a fuse blown but probably no access. Get a meter and check voltage coming out of the charger , that will tell you a lot. It could be something simple like where you plug it in on the Segway that jack is bad. Can you access it to see. I will check back but I'm sure it's something simple like that. That jack get abused the most so there you are , the first rule of troubleshooting.
Score 1
Add a comment
I opened my sons hoverboard and the charger wire was not connected. You may want to check the charger wire and slightly tighten the wire.
Score 1
Add a comment
Put the transformer in a hard surface and press down hard on the grooved part of the cover. I did this and the light went from red/green to red solid for charging. This would indicate a loose connection somewhere in the circuit board, but may work for now.
Score 1
1 Comment:
My sons swegway is just flickering the power and the battery icon when trying to turn it on
by
Add a comment
I had the same problem. Like everyone I checked all the connections, tried a new charger. I replaced the battery, it works and charges like a charm. I checked the voltage on the old battery and I have a dead cell. Took to a local hobby shop to confirm, it was a dead cell. They told me that the Lipo Batteries won't charge if you have one dead cell. So, check your connections, and buy a new Samsung or LG Battery and it will work fine.
Score 1
Add a comment
I had the same problem. I couldn't get the light to go to red. I got it to work, here's what I did. I took off the cover where the charger port is. There are wires connected to the port and motherboard. My wire was disconnected where it should be soldered to the charging port. I plugged the charger in, as I touched the wire to the empty post, the light went to red. Hooray! A little electrical tape to hold it there, and it charged.
Score 1
Add a comment
Try this. Read it on some blog. Disconnect your charger from both ends. Make sure your segway is off. Now before connecting the charger to the segway make sure the other end is not already in the socket. Only after it is inserted in to the segway then only plug the other end and now try turning the main switch on. Your charger light should go red. If it works do let me know.
Regards
Update (01/09/2016)
Fixed it. Thanks guys. Opened the back panel from the charging side and the charging wire socket was lose. Unplugged it from the board and plugged it back and it started charging.
6 Comments:
I fell off my hoverboard today and now it won't turn on.. it just shut off when it rolled 2 times. No red light or nothing come on somebody just txt me and give me some ideas I just got this hoverboard too 6363590872
by
Check your instructions. It may need to recalibrate it.
by
Sorry, I have the problem that when I put the charger on and it stays green.
So the battery on the hoverboard is totaly finished, it doesn't turn on because it hasn't got enough energy. What can I do to make it charge??
by
My son took his over to friends house. They has plush carpet and apparently got debris around one wheel axle. He cleaned it out but,now that one wheel wont roll smoothly and that side wont operateHelp!
by
My hover board charger won't even turn red or green
by
Show 1 more comment
Add a comment
Many thanks for these facts and helpful opinions. Daughter got one for Christmas and its dead. Charger is green but no light on board. So with the help of u guys, we r returning to the supplier, bluefin who will hopefully replace 2 day faulty for new on pick up?
1 Comment:
Can anybody help me ?
When i tried to charge the hoverboard 4 the 1st time there was no light indication of charging and afterleaving it in charge 4 long time it was not runing
by
Add a comment
Loljhytyyhhhhhyyyyyu
4 Comments:
My hoverboard came with a u.s.a charger, is it safe to use an adapter or plug into razor point in bathroom.
by
On one of the Segways I bought the battery indicator stays orange after being charged 3 hrs. Can anyone help?
by
My sons hover board the battery light is staying green Nd it’s beeping non stop Nd the blue lights r on it will not turn off any idea
by
Just got a glide board yesterday and my daughter has used it for about an hour now it’s battery is flat. The charger won’t work. When the charger is plugged into the wall the light is green - when I then plug it correctly into the board the light goes off and it’s not charging. Any ideas?
by
Add a comment
I just bought the libery 1 hover board its fully charged but cant get it to turn on. any suggestions
Add a comment
++https://www.ebay.com/itm/202978676519++
Did you get a new Segway Ninebot minipro or minilite and it won't power on or charge, or did you let it go too long without using it and now the battery wont charge, or do you have the dreaded 4 red blinking led?
If you are a Technically inclined individual and would like to do it yourself and do not like to mail your battery to us - This listing is for YOU.
Thus far we have successfully restored 100% of the batteries with a special jig we designed to provide safety, eliminate soldering and risk by following the step by step instruction to the letter. (Important: You need to have the original Ninebot charger not any aftermarket substitute.)
You will be responsible for removing the battery from your Segway(4 #3 Allen wrench screws),
...or send me an email direct: Manny_Lalo@hotmail.com
Add a comment
Hi we got a seaway for our sons birthday on Wednesday hes only had it 3 days it woudnt charge today and we notice the hole you charge it in should have 3 pins but only has 2 pins so the charger won't fit and charge .
has anyone ever had this problem?
Add a comment
https://youtu.be/0O9SIraAuAU
Add a comment
Hey guys I have a Segway ninebot mini pro I get the voltage cell error indicator on my phone….the battery has no light once I plug it in the light turned green ..I unplugged it it stayed green ..I've seen videos where you take the battery case off check your sodering ...jump start your battery but taking exposed wire to the ports…same issue it was still green..anyone having experience with this? Please help my name is Dave I would greatly appreciate any help.. I appreciate all your questions and answers thus far...Its been very informative!!! you're all amazing people for helping each other in this manner!!
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 40
Past 30 Days: 201
All Time: 123,617
