no service iPhone 5c
searching then no service on iphone 5c date and time and antenna are ok????
Hi, I would check resistor C940_RF under shield close to Battery connector!
Thank you but isn't that a capacitor, do you mean check for a short? I was thinking it could be the baseband but I don't know where it is located on the 5c.
Look in settings if you see the IMEI number. If not, it probably is a baseband problem. The chip is located under the EMI shield below SIM tray. It is the Qualcomm one.
Note that you can't replace it because the chip is linked with the serial number of the iPhone. If a reflow/reball don't work, you lost the phone feature.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 340
