Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Maintaining programs & software through hard drive upgrade
Hello
I have several software programs from when I was a student installed on my 17" unibody mid-2009 Macbook Pro, and need to retain this software while doing a hard drive upgrade if possible. I am curious if doing a Time Machine backup to an external HD, then somehow restoring from that external drive would work.
Any feedback or resources would help
Thanks very much
Score 1
Add a comment
1 Answer
Chosen Solution
If you have an external FireWire HD case (this is best in your case) you can make this very easy.
During the OS install process you'll be asked if you want the migrate your data from your old system to your new drive. That allows you to copy over the apps & user data as well as the permissions.
I do recommend you first make a backup on an external drive using TimeMachine just because the next action could mess things up. This is were you boot up under an external drive (USB thumb drive will work here) so you can repair your drives permissions and any disk errors. Then proceed with the upgrade.
Score 4
2 Comments:
If you really want to be paranoid, you can use something like SuperDuper to completely copy the old drive onto your new drive. I've done that with an external USB hard drive dock, and it works VERY well.
by
This is one program that works well enough for me to get the paid version. Great Product! http://www.shirt-pocket.com/SuperDuper/S... And the registration stays with you through updates.
by
Add a comment
Add your answer
Tyler Stark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 107
