A collection of guides and support to help with washer repair.
3482 Questions View all
My washer doesn't spin makes clicking sound
I have a Kenmore elite top load maybe 8 yr old. My drum does not spin and makes a clicking sound after the rinse cycle and then I move the button and then it engages and starts working? Help
1 Comment
If the washer has extra slow slow and fast agitation then it is a three speed motor. Those motors tend to go bad. The centrifugal clutch is what is clicking trying to engage the motor. Whirlpool 2 speed motors are practically bulletproof but the three speed motors suck.
by
Add a comment
1 Answer
Chosen Solution
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer may stop mid-cycle. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
Cause 2
Door Lock Motor and Switch Assembly
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the washer door is not latched shut, the door switch prevents the washer from operating. If the door lock is defective, the washer may stop mid cycle. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, consult your washer’s diagram and use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
Cause 3
Water Inlet Valve
During the rinse cycle, the water inlet valve opens to allow water to enter the wash tub. If the water inlet valve fails, the washer will continue waiting for the water to enter the washer, causing it to stop mid-cycle. To determine if the water inlet valve is defective, use a multimeter to test it for continuity. If the water inlet valve does not have continuity, replace it.
Score 2
1 Comment:
Did anyone actually read the question it makes a clicking sound hello.
by
Add a comment
Add your answer
Barlowb will be eternally grateful.
Past 24 Hours: 9
Past 7 Days: 27
Past 30 Days: 164
All Time: 34,265
