Repair guides and support for a wide range of Vespa scooters.
14 Questions View all
starting issue, battery good, makes noise but no start, ideas? Randy
206 vespa, 900 miles, no start and battery tested good, just makes a noise but no start< Randy
Score -1
3 Comments:
You'll need to provide a lot more information, there are many things that can prevent it from starting. What model of Vespa? You are saying the starter is not turning the motor over? or the motor is turning but not firing? Is the noise a clicking or a whirring noise?
by
rappinrandy , what noise does it make? What have you checked?
by
RE: 2001 Vespa 150 CC
My Vespa has been on a battery tender almost a year and I have started it up with no problem. This morning, it would not turn over. Has gas though it is old. Has oil but again, it’s old.
Any suggestions / remedies?
Thank you,
by
Add a comment
hi
1st check your fuel system if it feeds correctly and make sure the carburators are clean
2nd check your high tension wires if it does fire up your spark plugs
hope it helps
1 Comment:
i bet the noise your hearing is from the starter when it try to start the engine.
by
Add a comment
Starter Bering's locks or neutral safety switch is bad
Add a comment
Add your answer
rappinrandy will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 356
