water is draing from front bottom pannel of washer.
Why is there water comming from the front pannel of washer ? And do i have to wash / rinse in a warm or hot temp setting or can i use cold/ cold settings ?
hortoncindy1503 you may have a leaking drain line or a leak on the drain pump. to verify this you will have to take a look under the bottom of the washer and make sure that all hoses are properly connected. For whites, typical dirty clothes and diapers, use hot water (130°F or above). For man-made fibers, knits and jeans, use warm water (90°F). For dark, bright colors that bleed or delicate fabrics, use cold water (80°F).
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 77
