Washer not finishing cycles F35 code
Washer not finishing cycles showing F35 code. How can I repair?
Gary Grigery, here is my answer to a very similar question "F35 means that the unit is flooding because your pressure switch has failed. First open the door manually, then replace the pressure switch under the top panel mounted to the right side wall to get rid of the error. To unlock the door, remove the 3 screws along the bottom of the lower front panel. The panel will then pull straight down and off. Once you remove this panel you can reach up behind the upper front panel and pull down on the small plastic pull tab attached to the bottom of the door lock assembly. This will manually unlock the door so you can open the door.
To access the pressure switch, pull the washer forward and remove the 2 or 3 screws coming in from the back of the top panel. The top panel will then pull straight back, up, and off. The pressure switch is mounted to the right side wall above the tub and is the only part with several wires going to it as well as a small rubber hose. from here. Here is a decent video that should help you work on your washer.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 839
