Machine doesn't boot, I hear HD spin a second, no lights...
Hello everyone.
I have a Apple Macbook Pro 15" (2.33GHZ/2GB/256 VRAM/120GB HD) that will not boot up. When you go to power on the machine the computer doesn't start, rather you hear the HD spin for a quick second (not even reaching full speed, more like a kick) and then nothing happens. No lights, no display, no fan, no nothing. I'm not even sure the machine even gets as far as starting P.O.S.T.
Any help or suggestions will be greatly appreciated.
Add a comment
Chosen Solution
You need to start from the power source and work forward. First thing is seeing if you get a light on the Magsafe adapter. Next would be the DC-IN port. Use a multimeter and start checking.
Score 2
Add a comment
Sounds like your logic board is bad or something is wrong with your battery that is killing it on start up. The Mac has four steps during start up, the first one being hardware check. If it fails at this point, your computer will still continue to run--you just don't see any flashing screen or chime. The issue is most definitely hardware related. Assuming your laptop is out of warranty, try removing all accessible hardware and starting up the computer. If that still fails, I would call it an issue with the logic board(assuming the battery is functional).
Score 1
Add a comment
Add your answer
Jamil Moore will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,946
