Repair guides, support, and troubleshooting information for MacBook Air models with 11-inch displays.
930 Questions View all
Yosemite installation stuck, how long it takes?
Hello,
I’m installing macOS Yosemite on my 11” MacBook Air, but it gets stuck at "downloading additional components" and it says 2 minutes left. It's already more then 11 hours that I’m waiting and I don't think this is normal.
There is also the little circle running since yesterday night ... what should I do?
Reinstall the OS again?
Thanks
Update
I’m doing from internet, and I formatted the drive using disk utility (mac journaled...) , or something like that.
Score 1
1 Comment
Are you doing this from the internet or an external? How was the drive formatted?
by
Add a comment
1 Answer
Chosen Solution
Yes, reboot and run the update again. I've seen this on a couple of older machines, especially if WiFi is inconsistent.
Score 3
4 Comments:
It's not an update, I erased the SSD and I want to fresh install yosemite (the machine is 2013)
Anyways... like you said I think I ll rebook and try to install the OS once again
thanks
by
Absolutely. Just re-run, don't worry about erasing again.
by
Thank you my daughters Mac air had to be erased and reset and mavericks was taking ages to reinstall it was saying 13 hours!!!! I knew she wouldn’t be that patient! So I did what you suggested- and clicked cancel and then reinstall again and now the blue bar is cruising along nicely and it said 41 minutes that us now down to 29 after less than 5 minutes since starting! Thank you so much (thus far anyway!)
by
Yes, that's right.
thank you so much.
by
Add a comment
Add your answer
patriziopanelli will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 5,714
