Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Question Closed
How can I fix my sleep button, it is non responsive?
Can not power off or reset which causes major issues. I can repair it with a guide or a part if it is avail. Please Help, your my only hope..-_-
Add a comment
Chosen Solution
If it is the ribbon with the switch on it get ready to tear you phone apart. It is not an easy repair I did two in the last two days. The ribbon runs from the power switch to the headphone jack then over to the mute switch and volume up and down buttons. Everything has to come out! The good new is the part is cheap and if you can pull it off you will have preformed a fairly difficult repair in my book.
Add a comment
so solace 01, about how much would you charge to get that sleep buton fixed!?
1 Comment:
iPhone 3G/3GS Headphone Jack Assembly
guide to install is also on this page.
you can also buy from online shops fairly cheaply
by
Add a comment
I did it! Bought the part and switched it out, hardest part configuring the locale of the silent button. I had to do a tricky bend with the ribbon cable to make it work right, thanks for the help.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 8,559
