Simple to use 35 mm manual focus SLR camera. Model number X-370.
The shutter won't work
I've taken it to a a few places and they're not sure on how to fix a camera like this. i've tried to get the shutter to work when i want to take a picture, but there never is the sound that it goes off. Is there any way to repair it or some simple way to gently take it apart and make sure that it still does work? I just don't want to take it apart and break something...
i rather enjoy this camera then the new digital ones that sell for way too much.
any help would be greatly appreciated :)
Score 2
Add a comment
Chosen Solution
Due to the age of the camera your problem is not the battery but the release capacitor located on the bottom of the camera when you remove the bottom plate. You can replace this capacitor yourself, just unsolder the old cap, but pay very close attention to the polarity of the cap when removing so you can put the new cap in place the same way. Put fresh batteries in and it should start working again.
I have 13 years experience in repairing camera equipment and i used to see these come across my bench a lot for the same problem you are describing.
Score 2
3 Comments:
Try changing the batteries first. This corrects the problem on at least 1/2 of the ones I come across
by
Can the capacitor can be 10v?
by
@tigrebici - I think there is a translation issue here as the electro magnet is what often fails. The bar piece is held by the permanent magnet and when the shutter button is pressed the inverted magnetic flow cancels the grip of the magnet, thus the shutter is released.
Often times the mating surfaces get fouled by oil causing the bar to stay stuck when it should have let go. After popping off the bottom plate you’ll spy the magnet, take a thin strip of paper dipped in acetone the then squeeze in between the bar and magnet cleaning the two surfaces I would do this at least twice. See if the solves the problem and also look for sand and corrosion as that too can mess things up.
by
Add a comment
Assuming the battery is good, their is a small capacitor in the base of the camera that must be in good condition.
Add a comment
Add your answer
cb13yrjourney will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 65
All Time: 5,110
