Gaming and high-performance laptops under Dell's XPS (Xtreme Performance System) brand.
108 Questions View all
Not able to hear properly from one speaker. How to fix it?
Hello,
I am using Dell XPS 15 L502X laptop. I am not able to get clear sound from my laptop speakers. It feels as the sound is coming from one speaker and connection is broken from the inside. Can anyone please tell me if it is possible to check the connection of the speakers to the motherboard and how?
Thank You
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
To ensure this isn't a settings issue, go to Control Panel - Hardware and Sound - Sound. Under the playback tab, select your speakers and click configure, then click test. It should play sound from both sides regardless of how they are set up in Windows.
If both speakers function well on the test, you will need to adjust the balance of your speakers.
If you still don't get sound from both speakers during the test, you will need to disassemble your computer (if a guide is not on iFixit, you should be able to find one somewhere online), find which speaker is broken, and follow the wire to the motherboard where it should be firmly connected. If it is not, plug it in and test the speakers again. If it still doesn't work, you will need to buy a replacement speaker.
Score 1
Add a comment
Add your answer
varunsaini2010 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 127
