The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
149 Questions View all
Question Closed
not charging the battery.
On 26th, my mobile fell in toilet,from charing side it was completely in the water. That night i kept the mobile in the rice on the 30th it was removed,the mobile is working as it was before,but it is not charging the battery.
Add a comment
1 Answer
Chosen Solution
rakesh, eemember that Rice is not going to clean your phone or prevent corrosion. It does not do anything. First thing to do, is to remove the battery and no longer try to turn your phone, to charge or to sync it. Disassemble your phone, using these guides to help with that. Once you have it totally disassembled, clean all the parts with a high grade isopropyl alcohol. Remove any EMI shields to ensure a proper cleaning. Check this guide for a proper procedure. Even so it was written for an iPhone, it will still be of help to you. Of course, if you have access to an ultrasonic cleaning, that would be the better way. While you clean your phone properly, check for any missing, burned or otherwise damaged component. Check all your flex cables, clean the connectors as well. Once that is done, replace the battery and reassemble your phone. Then re-evaluate for any further damage.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 73
