auto error code po 0400
What does error code PO 0400 mean and how to fix this on obll diag meter
joe greco, the P0400 Exhaust Gas Recirculation Flow Malfunction
Possible causes
- Exhaust Gas Recirculation (EGR) volume control valve stuck closed
- Faulty Exhaust Gas Recirculation (EGR) volume control solenoid valve
- Faulty EGR Valve
- Faulty EGR temperature sensor and circuit
- Exhaust Gas Recirculation (EGR) solenoid valve harness is open or shorted
- Exhaust Gas Recirculation (EGR) solenoid valve circuit poor electrical connection
- Dead (Weak) battery
from here So check the parts that could be causing this error one at a time. Start with the easier once than work your way up to more complicated and expensive
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 157
