Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
which flux to use for replacing chips on logic board
i dont know which flux should i use to replace chips on iphone 5/6
i have seen some body using liquid shiny flux on youtube that melts solder underneath the chip and chip comes off very easily
does anybody know the name
Thanks for helping
Score 2
Add a comment
1 Answer
Most Helpful Answer
Getting original Amtech flux used to be difficult. Amtech now sells direct (AMTECH VS-213-A-TF) so you can order it directly from the manufacturer. It works really well but I don't appreciate the smell.
Another alternative I like is the MG Chemicals 8341 (https://www.mgchemicals.com/products/sol...) It is very easy to source and works as well as the Amtech without the nasty odour :>).
Another flux that gets recommended is the ChipQuick SMD291. It works well enough but I don't like it because the flux tends to crystallize when heated making it very hard to clean off the board. That's okay on large robust, boards but on the high density iPhone logic board, sometimes with delicate micro-jumpers, it requires more work than it should.
Of course, they all do the job they're supposed to. The rest is all personal taste and every micro-solderer will have varying opinions. Try for yourself and see what works best for you.
Score 2
Add a comment
Add your answer
moonlight1 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,038
