frost build up in the back freezer wall
Hello -- I have frost build up in the back freezer wall of a GE fridge model GSH25JFXN. I did some research and try to find the problem. I used the OHM meter and went across the heater and thermistor. I had about 21 OHMS which supposed to be good according to the you tube video that I watched. and I checked the temperature sensor according to the video I supposed to have 16 k ohms when the temp. is around 32 degree F, around 5 k ohms when temp. is about 70degree F. since those component checked out ok according to the video so I thought the mother board is bad so I ordered the new mother board and replaced it. Now I still have the same problem so if there is anything else that I need to check ?
thank you in advance.
