13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Black screen but external display works.
Hi,
The screen on my MacBook (Late 2008) does not work. An external display works well. However, when I go to system preferences -> display, it's as though the 13" display does not exist. I have tried removing the battery, and resetting the NVRAM. Any suggestions are welcome
Score 1
2 Comments
Hi Philip, I have a similar issue: screen is black lighted, but connecting it to a n external monitor it works. even the camera does work actually. Did you solve changing the cable? do you think it was impossible to do at home? thanks
by
Yes, Francesco, replacing the cable, which requires replacing the display, resolved the issue. This task can be done at home. However, I would not care to attempt the task myself. Good luck,
by
Add a comment
Chosen Solution
You can try disconnecting the display cable and reconnecting it. It's step 9 in this guide:
MacBook Unibody Model A1278 LCD Panel Replacement
Add a comment
Thanks Michael. It turns out that the cable was damaged and must be replaced. I am going to let a professional do it.
Add a comment
Add your answer
Philip Huffman will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 128
