Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
half screen doesn't work after replacement
I replaced my screen using the guide, but after I turn it on only the upper half of the screen works.
the bottom half is black/white but does react to touch.
I have started over again but still no change.
What can I do ?.
Score 1
Add a comment
1 Answer
Hi
if the touch pane is working, it means that the touch screen digitizer and its flex cable connector contacted well with main board.
if the LCD panel is not working, it means that the LCD panel and its flex cable connector not contacted well with main board, it appeared many issues like yours.
solving solution:
1. connect the dock into connector in main board again, please make sure that the dock connector on LCD panel 100% contact with connector on main board!
2. if you still have the same problems, pls check the LCD digitizer assembly is compatible for your phone?
3. make sure the flex cable that is connected with lcd panel is good, have no any damage or break. error or improper cooperation will cause it during the replacement.
4. if the quality of LCD panel is poor, it cause many quality issues like black, white screen and have grids or lines on the screen. pls confirm it.
Add a comment
Add your answer
maya will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 111
