troubleshoot blinking green light
Mitsubishi WS-55859 blinking light occurred after storm. light blinks continuous
frank de los reyes, for blinking light symptom you should try replacing the capacitors on DM first. Download some instructions from here. The link will directly download a PDF file describing how to replace the caps. Also, check this guide Different model same issues same layout. This model series was plagued by a bad DM module that caused multiple failures on all other boards. there were also issue with the EEPROM Board failure after power outages.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 79
