The current line of iPod touch comprises seven (7) different generations.
2619 Questions View all
Question Closed
I need help with my volume! Please I cant live without music!
Ok so, i have an ipod touch that i always listen to music on. Well thismorning i was gonna listen to music when the volume glitched. Well when i turned down the volume all the way, it muted and the sound bar, that thing that u slide to raise volume, well it disapeered. And i cant turn the volune up using the buttons! Please help me!! Please!
Add a comment
Most Helpful Answer
Hey hunter iverson, this could just be an iOS issue or a hardware issue. Here are some things you can try:
-Reboot your device (turn it completely off then turn it back on)
-Test the audio by going on the Safari and try to listen to music to see if it works.
-Test audio on other apps.
-Do a quick hard reset. Press and hold the power and home button of your iPod for about 10 seconds. Once the iPod turns off then back on, let go then test the volume.
-It could be a corrupted iOS so restoring your device might help.
If nothing mentioned above works, then do the following hardware fix:
-Select your certain iPod Touch from here and then do a quick tear down and reassemble it back. Then check to see what works.
-Let me know how it goes.
Score 1
Add a comment
hunter iverson, disappearance of the volume slider is usually directly related to the dock connector. Remove all lint and other debris. Clean it with a toothbrush and some isopropyl alcohol. If that does not restore it, replace the dock connector...
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 85
