Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Question Closed
New RAM not responding.
Hi all,
I Installed new RAM details below, then when I switch on the computer, nothing but the fan appears to function, left it a few minutes (5) but nothing happened so tried with just one module of 8GB and the same result.
I reinstalled the old RAM and the MAC is now working as before? ideas....
My MAC is the following....
  • OS Yosemite
  • Version 10.10.3
  • MacBook Pro Mid 2010
  • Processor 2.4 GHz Intel Core 2 Duo
  • Current Memory 2 GB 1067 MHz DDR3
Trying to upgrade to 16 GB RAM (2X 8GB)
Is the "Unbuffered, Non-ECC, Non-Registered" the issue
New RAM details
EAN 4895187101871
  • Brand QUMOX
  • Bandwidth DDR3-1600 (PC3-12800)
  • Feature Unbuffered, Non-ECC, Non-Registered
  • Use for Laptop
  • Type DDR3, SODIMM
  • Memory Type DDR3, SODIMM
  • Bus Speed PC3-12800 (DDR3-1600)
  • number of modules 2
  • Capacity per module 8 GB
  • Capacity 16GB (2x 8 GB)
Add a comment
Chosen Solution
The problem is that you have the wrong replacement RAM module. RAM requires that you match the specs very precisely.
You can find the existing RAM specs in System Profiler, or by running the following terminal command:
system_profiler SPMemoryDataType
Match the speed (MHz), and whether or not it uses parity bits (ECC).
You can also look up the maximum defined memory that the system can reliably use. It's not going to be a given that you can install 16 GB. If memory serves, that model can accept 8GB without trouble.
Score 1
1 Comment:
thank you trodriguez i'll do as you suggest.....
Cheers
Dusty
by
Add a comment
Most Helpful Answer
To add specifics to trodriguez's point: You're using RAM that's two generations newer than your computer was designed for. A Mid 2010 MBP uses PC3-8500 DDR3 RAM (1066 MHz); you've installed PC3-12800 DDR3 RAM (1600 MHz). The first generation of MBP that used the faster RAM was the Mid 2012 generation.
Sometimes RAM can scale down to work over a slower bus, but it's not a sure thing. Your best bet is to get the PC3-8500 RAM your machine is designed to use. iFixit doesn't carry 8GB SODIMMs in this speed, but OtherWorld Computing has a 16GB kit for your generation. I'd check with the retailer you got your current RAM from first, and see what the charge will be to swap it for the correct speed.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 2,312
