My BlackBerry Curve 9320 phone is not getting started...
my phone is not geeting started after software upgrdation ...
I had the same issue and fixed it with a hairdryer! Try taking out the battery, blow drying it for a little while on all sides. Then blow dry the keys of the phone and inside where the battery goes. I don't know why it worked but it did. I assume there was either dust blocking connections, or some moisture causing issues.
hello Hari Saladi ,
it is very easy to fix your phone. case is the firmware not update properly
Use this line to download JL commander
after updating the software you can use your blackberry with better performance ever !
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 13
All Time: 424
