Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Question Closed
iPhone 4S water damaged, flash & speaker problem
Yesterday I was soaked in rain, but thankfully my iPhone 4S was in my bag. So, it was not drenched but was in touch with water for about an hour. When I reached home I saw the Flash light is on. From the process of trying to turn it off to the last time, the phone has been shut down and started for about 5 - 6 times. All this times, it was everything okay (touch,wifi etc.) except the flash (always on) and speaker sound (it was giving broken sound). So, finally I've put it inside rice around 12 hours ago and kept it air-tight.
So, what should I do now? How long to keep it inside rice? When I will take it out, charge will probably run out. Can I charge it to test?
Note that, I am not in a situation to open the casing manually but may be (yes, may be) I will be able to take it to a repair shop. Oh and I saw the water-damage-sensor in the bottom (can't locate the one in microphone jack properly), it was white, not red or pink.
Add a comment
1 Answer
Rice is a myth, you'll need to open the iPhone and clean the components in isopropyl alcohol and likely replace the battery. If you don't want to tackle this yourself get it to a repair shop asap. Do not try to charge the phone or turn it on. Leave it off to avoid further damage.
1 Comment:
actually I don't have good repair shop in the area who can really work with iPhone. So, when I take to repair can you give me some suggested do & do not to ask to the repair person? also, drying with hair dryer works or harmful?
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 79
