An entry level smartphone released in April 2014. Available in black and white.
145 Questions View all
No One can Hear Me... HELP!?!?
Hi There,
I used my phone last night, it worked fine.
Today I can place a call, hear the person on the other end - but they can't hear me.
I tried the voice recorder as well (also worked yesterday) won't work today.
I need help, this is super frustrating.
I've had this phone less then a month.
HELP!
Score 10
Comments:
Thank You
by
I got this phone from cricket one day the next day people can't hear me on it help
by
@Charles Grispon you need to start your own question
by
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
Hi @judistime,
Have you ensured that you haven't 'muted' the phone?
If not then try using the earphones with the microphone attachment. Then make a call or get someone to call you.
If you still cannot be heard then there is a problem with the voice transmission circuit in the phone and it will need to be repaired by a reputable, professional phone repair service.
If you can be heard, then the voice transmission circuit of the phone is OK but there is a problem with the phone's microphone. It is either faulty, has become disconnected from the systemboard or perhaps the voice inlet hole on the bottom edge of the phone has become blocked.
To check this last possibility, use a magnifying glass and a strong light and check to see if the hole is blocked with dust or lint. If it appears to be DO NOT try to clear it using a pin or suchlike. You may damage the microphone which is directly behind the hole. Try a vacuum cleaner, using short sharp bursts to see if you can clear the obstruction.
If the hole doesn't appear to be blocked, here is a link to the Ifixit guide on how to access the microphone in your phone.
Blu Studio HD 6.0 Microphone Replacement
Score 2
Add a comment
turn off microphone permissions for google app. worked for me.
Score 1
Comments:
try this and if not working take phone to servise.
by
Add a comment
Try turning it on and off again and then use Aida 64 to see if it's mic is even being found
Add a comment
Add your answer
erynphotography will be eternally grateful.
Past 24 Hours: 31
Past 7 Days: 243
Past 30 Days: 1,229
All Time: 19,463
