Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
834 Questions View all
New battery will not charge but has good life?
So, I just got a new ifixit battery for my iPod video. Replacement was successful, and iPod turned on as soon as everything was hooked up.
But, now it won't charge. It is not shutting down immediately like a lot of other people report with their iPods. It is slowly running out of battery life like any battery would, not particularly slow or fast. But, when I plug it in it doesn't recognize it's charging and the battery doesn't seem to charge at all.
It is able to sync to iTunes without a problem, so there isn't an issue with the cord I'm using or the plug you put the charger/cord into (not sure what you call that).
Any suggestions? I'm not sure if I got a defective battery or need to replace another part. Anyone else experienced this?
Thanks!
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Just because you can sync with tunes doesn't mean the cable is still good for charging. Try a different cable. There are different wires inside your cable that perform different tasks. Charging is not necessarily done with the same wire as connecting.
Score 1
Comments:
I have used several different cables, including a brand new one. And they work for charging other devices with the same charger type. Thanks for trying, but I'm pretty sure it isn't a cable issue.
by
Add a comment
Add your answer
mercedesanderson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 73
