Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
Question Closed
Tools needed to replace trackpad
In the tools needed section in your manual it says to replace a trackpad I need a Y1 tri-wing screwdriver yet in the step by step procedure #5 it says to remove a 5.6 mm and a 13mm tri-wing to remove the battery. Will a Y1 that you are selling remove both screws? A little confusing. I already bought a new trackpad from you.
Add a comment
1 Answer
Yes, the Y1 driver included in this set will remove both of the screws for the battery on this model.
Add a comment
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 4
All Time: 167
