Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 Questions View all
Question Closed
Why does my iPad randomly get brighter?
My iPad 2 EMC2560 has lost much of it's brightness. It will randomly get bright (brightness level it should be), but it never lasts very long and I can make no connection between the events that lead to said brightness.? Any help/ advice appreciated.
Add a comment
Have you ever taken your iPad apart? If so, it may be a backlight issue with the LCD, in which case you need a new one.
It also might be a setting, on Apple devices you can make the iPad set the brightness automatically- make sure that's turned off.
Add a comment
Is your iPad in a case?, the case could be blocking the backlight sensor ( just above front camera) causing your iPad to think it is dark and should lower the backlight. Try remov Not the case of turning off auto brightness as You Just suggested
Add a comment
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 116
