Repair information and guides for MacBook Pro models with 13" displays.
9741 Questions View all
Long Screws Won't Screw In!
Hello! I was recently opening up my Macbook Pro for the first time, and all was well, but when I went to screw everything back in, the back three screws (the long ones) WILL NOT GO IN! All they do is just screw in a tiny bit then get insainly difficult to screw in, and I don't want to strip them, so I pull them out. Please help ASAP!
Score 4
6 Comments
P.S., The MacBook is from around 2011-2012 I believe.
by
What are the last four digits of your serial number?
by
Not sure how to find this @robert
by
It should be located on the bottom cover in this area
by
DV13 is the serial number. @robert
by
Show 1 more comment
Add a comment
Chosen Solution
It really sounds like you are talking about the bottom cover. With the machine inverted and the hinge facing away from you, the long screws go into the three holes at the top of the machine to the right. The far left hand screw in the back is a standard one. The short screws sound like you have them in the long screw holes. Gently lift the bottom plate up with your fingernails, as they really aren't attached and they should come out with the cover. Next time follow the guide.
Apple MacBook Pro "Core i5" 2.4 13" Late 2011 Specs
Identifiers: Late 2011 13" - MD313LL/A - MacBookPro8,1 - A1278 - 2555*MacBook Pro 13" Unibody Late 2011 Lower Case Replacement
Score 2
Add a comment
Are the screw holes I highlighted in blue obstructed in any way?
Score 1
4 Comments:
I cant quite tell because unfortunately, now the other screws wont come OUT.
by
A few of them, at least.
by
The top right three screws won't come out. They aren't stripped or anything. They just keep spinning and spinning. But from what I can tell, the screw holes aren't obstructed.
by
The threads may be stripped, if you take a pair of needle nose pliers, can you get any leverage?
by
Add a comment
Add your answer
Kerp Kat will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 7,877
