A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 Questions View all
I changed the keyboard
I changed keyboard in my laptop and now a screen comes up in blue saying something about drivers and something about new devices or hardware. Do I have to change any settings when replacing a keyboard
Score -1
Add a comment
1 Answer
Most Helpful Answer
if rebooting it doesn't fix it, you might need to go on the manufactures site,ie:hp.com, and click on support, have your serial number ready and model number, go to drivers and software downloads, on the search bar, type in your model number and it should list all the drivers that your system requires. download them and follow the on screen instructions, you might have to unzip the files. then restart your system and it should be good to go if the keyborad is a good one.
hope this helps, if not, take it to abest buy and ask them for advise, they usualy tell you how to fix it if it is an easy fix.
good luck
Score 1
1 Comment:
Thank you so much worked great
by
Add a comment
Add your answer
cherbear will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 42
