Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Wi-Fi greyed out, no flashlight, camera issues after screen repair
Hi
Today a customer gave me an iPhone 6 which he alledgedly 'fixed himself': he changed the LCD Digitizer assembly because it had a huge crack in it.
After installing the new assembly and booting it up, following things started going wrong:
  • Wi-Fi and Bluetooth stopped working; Wi-Fi toggle button became grayed-out
  • Rear facing camera worked, but couldn't take pictures. Hitting the big white button in the camera app did not take the picture anymore. Front facing camera worked completely fine.
  • Flashlight does not work anymore
  • Leaving the phone on stand-by for a couple of minutes will lock you out completely: it won't power on anymore, and you have to reboot by pressing POWER + HOME simultanously
What I tried:
  • Putting a cracked, but working OEM assembly in place
  • Disconnecting the camera
  • Cleaning the connectors
  • Disconnecting just about anything but the battery and the LCD / Digitizer
  • Software reset to factory defaults
None of these things changed anything. I already told him it's probably a lost cause, but I'm curious what might have caused this. I've seen several topics online with people having the exact same issues. Any ideas?
Add a comment
Most of Wi-Fi greyed out problem is due to a broken chip on the motherboard.
And most of the problem you listed seem to be a broken flex cable or motherboard chip to...
Take a look on motherboard if is there some broken chips.
Add a comment
I have exactly same issues but how can we check any broken chip on motherboard. ???
Add a comment
Add your answer
lorre851 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,450
